02-15-2021
16:48
05:41
02-15-2021
16:48
05:41
A few days ago my Sense would no longer sync to my Fitbit App on my Android phone. I have tried everything. (I uninstalled the app, turned the bluetooth off, rebooted my phone, have cleared my app's cache, force stopped the app, and now tried to re-pair my device to the app.) My Sense has now disappeared from my Fitbit App and I cannot get my app to connect/sync with my Sense. HELP!!!
02-16-2021 05:42 - edited 06-09-2024 05:17
Hi there @April96, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Sense as suggested by @Guy_.
In addition to what you've tried, please follow the steps below:
If you can't get started with your watch, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
02-15-2021 23:13
02-15-2021 23:13
In the phone Fitbit App Click on profile photo [top left] Click on + Set up a Device Follow the installation instructions |
Best Answer02-16-2021 04:44
02-16-2021 04:44
I have done this multiple times. When it does not find my Sense, it asked me if my Sense is powered on. My Sense was on and had 99% battery!
02-16-2021 05:38
02-16-2021 05:38
What is happening when it asks if the Sense is powered on?
What is your phone?
Best Answer02-16-2021 05:42 - edited 06-09-2024 05:17
02-16-2021 09:55
02-16-2021 09:55
Had to restart my Sense in order to reconnect it/sync it to the app.
Since I restarted it, I have lost all sleep related info (sleep log, skin temperature, SpO2, etc.) for the past 4-5 days!
07-23-2021 21:39
07-23-2021 21:39
I have spent almost as much time trying to reconnect my Sense to my Galaxy S21 as it has actually worked. I have had it for one month and am ready to trash it. I never had issues like this with my Versa 2. It won't stay connected to bluetooth. Spo2 only randomly works. If I use my earbuds, it requires a factory reset to get connected to bluetooth and then has to update for an hour before it is useable. I don't have enough time to spare to use a Sense. Actually, it really doesn't matter that it is not tracking sleep and sp02 because I am getting very little! I have talked with Fitbit support in the last month more than I have talked to my husband. This device is a great idea, but released way tooooo early and too many issues. So many users are frustrated with its inconsistent performance on so many of its advertised features.
