Hi, My Sense decided not to sync since Monday. This morning the Sense was unresponsive. I put it on the charger and after a few minutes it was at 77% so I know it didn't have to do with low battery. It is responding now, but glitchy and still won't sync. I have gone through all of the suggested fixes. I have restarted (twice) charged and turned the bluetooth off and on (phone.) No change. This is frustrating as I use my stats daily. I've only had my Sense for 8 months! I did try to Live Chat, but that isn't working on Fitbit's end for some reason. Help! Thanks!
Best AnswerUn-pair is done by removing the Tracker from the phones Bluetooth and not from the fitbit app. The user can not re-pair the tracker, any attempt will be blocked by the tracker since pairing is handled by the fitbit app.
@CathyG7 have you removed the tracker from the phones Bluetooth ( unpair)?
Have you restarted both the phone and tracker? This is called a soft(ware) restart
Actually it would be better to do a hard(ware) restart by turning both the phone and tracker off
Have you cleared the fitbit apps cache?
Best AnswerI have had my Sense for about 3 months. 3-4 times a week I have to turn off blue tooth and log out, which usually works. Sometimes I have to do it several times, as well as reboot. Often I have to delete the Sense and then add the device back. It can easily take over 30 minutes to get it to sync. This issue needs to be fixed.
