08-30-2021
13:43
09:56
DavideFitbit
08-30-2021
13:43
09:56
DavideFitbit
After fairly extensive testing over 8 days against a Garmin 66i, OSGB Mapping and even my old Fitbit ionic, the Sense is producing a frequent inaccuracy of between 350 - 700 meters. This makes any metric based on these readings hopelessly inaccurate E.g Average pace etc.
I’d be very interested to know how Fitbit quality check their products before release.
This needs to be a priority fix, if indeed it can be fixed by a firmware update. I’m very disappointed that even compared to the 4 year old Ionic, Fitbit appear to be moving backwards!
Moderator edit: subject updated for clarity + format
Best Answer09-09-2021 11:33
09-09-2021 11:33
Hi, thank you for sharing this information about the trouble you've been experiencing with your Sense watch, @RealSting.
If the GPS is getting disconnected during your activity, the Sense may track different information for the the distance. Before considering other options, make sure to follow the steps suggested in this article.
All devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time.
If you continue to see the same behavior and your GPS is not getting disconnected, make sure to try following the steps listed in this article to complete a restart and check if you're still experiencing the same behavior.
Hope this helps.
06:07
09:57
DavideFitbit
11-15-2021
06:07
09:57
DavideFitbit
Hello DavideFitBit,
My tests are fairly conclusive and point to an issue with the Sense’s GPS/firmware. I didn’t mention in my previous message that the GPS was being disconnected at any point. Please read my message before responding to it - I already know all about GPS systems Thank you very much! Watch has been reset and that makes no difference as I expected! Your link(s) point to non technical and very basic scripted answers that don’t relate to the issue, moreover, they don’t work. I’m beginning to think that the moderators on these forms are pointless as they don’t add any useful info or solve any problems.. just useless scripted answers proving their lack of knowledge.
Fitbit, pull your finger out and fix the issue(s) before I (and likely many more) leave Fitbit altogether.
Moderator edit: format
11-16-2021 01:35
11-16-2021 01:35
@DavideFitbit , frankly, Fitbit should not stick on this kind of routine answers. You must admit that GPS inaccuracy of Sense and Versa 3 is a real issue because that is obvious. We have enough knowledge about GPS. We know how it works. In my experience, my Versa 3 always records a distance around 5% less than the actual distance. This is not within a normal error, and, as @RealSting mentioned, it makes all the data based on the distance meaningless. Fitbit, please face it, figure it out and fix it! Thank you!
11-16-2021
10:15
10:09
DavideFitbit
11-16-2021
10:15
10:09
DavideFitbit
My Sense only a week old.... Won't synch... Having to charge every other day and it does not accurately measure my Miles ran on treadmill its out by 2 miles.... Not had this on Versa...
Hi I had my Sense for week now and am having same problems....I run 5 miles daily and its now only registering 2.6miles.... Way out.... I had no problems with my Versa.... I got fobbed off on here saying it was a GPS problem.... Sorry but no... Its a sense problem.... I am fuming
11-25-2021 10:02 - edited 11-25-2021 10:03
@RealSting @deiG @Skyegirl1 Thank you for all your replies and for taking the time to share your feedback about the product. I'm sorry to see that you're still seeing inaccurate distance.
Since you already tried all the basic and general recommendations to improve accuracy of GPS and you continue to have the same problem, I do recommend that you get in touch with the Customer Support team for further assistance. They will let you know how to proceed.
Thank again for all the information and feedback provided. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a good day.
Best Answer11-25-2021 10:11
11-25-2021 10:11
Best Answer12-01-2021 06:00 - edited 12-01-2021 06:00
Thank you for the update and for all the feedback, @Skyegirl1.
I'm sorry to see that you had to return your watch due to this inconvenience.
Have a good day.
