05-26-2023
18:04
06:05
05-26-2023
18:04
06:05
My sense completely died this morning without any warning signs. This sense was a replacement unit from fitbit for a faulty unit that i purchased.
The battery was last seen at around 70%. Screen total black out. App can’t detect and sync. Try reset but no response.
Please advise. Thank you.
Hi @SunsetRunner - it could just require charging. Check how long ago it shows it was at 70% in the app it could be several days ago.
Try charging and check it doesn't get hot and if so stop immediately as it has internal damage.
If it is not charging see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
It could be a charging fault but if the watch suddenly died unexpectedly it could have got moisture in it causing internal damage.
