11-18-2023 22:09
11-18-2023 22:09
I cleaned my sense with a cotton tip around the contacts and speaker/microphone holes. The lights on the back were flashing while I did that. Then I went to charge it but the screen was all black and hasn't indicated it's charging.
I've read all the other forum posts about holding down the button til it vibrates and charging etc. But none of that works. It's not getting hot while charging.
I still get a vibrate while charging but it won't actually turn on. Sense is 2 years old, any help welcomed!
11-18-2023 23:06
11-18-2023 23:06
Hi @MeganDavies - it may not have sufficient charge to start see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Once you are sure it is charged, if it is still syncing check charge level in the Fitbit App, hold the watch button for a full 10 seconds until till it vibrates and the logo appears and then wait for it to start.
If it is syncing try also changing clock face though a double tap and swipe should still produce a response.
Best Answer11-19-2023 03:20
11-19-2023 03:20
It's been 'charging' for many hours, but still won't turn on. I've checked and cleaned the terminals on both the sense and charge cable. I've also swapped the power outlet connector, but still 5V.
It won't light up and it won't sync with my phone either. I can't turn on the screen or swipe through the face options.
Any other recommendations?
Best Answer11-20-2023 13:43
11-20-2023 13:43
Mine is doing the exact same thing as yours. Mine was completely unused for like 6 months and now it no longer works.
Support basically just confirmed that its no longer working and offered me a coupon to buy another at a slightly discounted price.
I'm curious if you have better luck.
Best Answer11-20-2023 18:35
11-20-2023 18:35
Hi @DanHeintzel - if your watch was faulty the last time you used it and is why you stopped, it will still be faulty.
Though follow the link given previously and in addition if it hasn't been charged for that long it may need several attempts to wake it up, especially if you got a red exclamation mark and low battery.
Try unplugging the USB for a minute and then start charging again, assuming the charge cable is ok? And leave charging for 2 hours, providing it doesn't get hot in which case stop immediately.
Best Answer11-20-2023 22:33
11-20-2023 22:33
My watch was working perfectly fine before I stopped using it. There was nothing wrong with it.
when I plug it in, nothing happens. It’s been on the charger for 5 hours with zero response. No vibration when plugged in, no heat, no exclamation mark.
Ive tested the cable with a multimeter and the cable is not an issue.
Best Answer11-20-2023 22:48
11-20-2023 22:48
@DanHeintzel- there may be some oxidation and the contacts need proper cleaning but examine the cable as mentioned earlier, if there is a slight difference in height of the pins they may not make contact, even if there is a voltage. How do I clean my Fitbit device?
Best Answer11-22-2023 01:15
11-22-2023 01:15
This happened to mine .
I removed from Bluetooth settings .
I downloaded the fitbit app.
I followed set up device .
it showed 77% battery .
Then showed update .
which I did .
Now it’s on and working again .
Good Luck
Best Answer11-22-2023 08:12 - edited 11-22-2023 12:35
Mine is not turning on at all though
Best Answer11-22-2023 11:57
11-22-2023 11:57
I ended up doing a virtual chat with someone as I wanted to get it repaired but there are no authorised repairers.
I confirmed I'd followed all the instructions both in this chat and as they gave them to me.
I have now packaged up the unit and posted it to them. If it can't be repaired then at least I tried to get it fixed, instead of just throwing it out. We live in such a wasteful society.
Best Answer11-22-2023 12:25
11-22-2023 12:25
11-22-2023 12:37
11-22-2023 12:37
I do plan on cracking it open myself and taking a look. It’s not working as is, so there isn’t much harm in trying. I suspect either a connection broke, or the battery is having issues.
I agree with you. This watch isn’t anything groundbreaking. It shouldn’t be something that people have to cycle through and replace every year. it’s extremely wasteful.
Best Answer11-22-2023 12:50
11-22-2023 12:50
@DanHeintzel - have you been through all the responses above and in your other posts?
Be aware that a discount is only valid on later watches which don't have all the features of a Sense, so might not be that appealing.
If you wish to stay with Fitbit currently there are some very good deals in the shops or even on other brands.
