10-05-2020 21:03
10-05-2020 21:03
I've had my Fitbit Sense for a week now and I haven't been able to successfully change the weather from Fahrenheit to Celcius. In the app I've gone into settings and changed the units to C, but on my Sense it still shows it in F. It's been syncing all my other data properly but I can't figure out why it isn't working with this. Has anyone else had this issue/been able to resolve it?
10-05-2020 21:21
10-05-2020 21:21
But you didn't say where it is showing F. If you are talking about the Weather,
on phone app click profile pic > Sense > Apps > My Apps > Weather > Settings.
10-05-2020 21:21
10-05-2020 21:21
10-05-2020 21:31
10-05-2020 21:31
Thank you, that was it! I didn't even know about that app section, so that helps a lot!
10-06-2020 03:07
10-06-2020 03:07
Thank you, that just worked for me.
Best Answer01-08-2021 05:26
01-08-2021 05:26
On my weather app it’s showing Fahrenheit but my Sense is showing Celsius. It was showing Fahrenheit all along until today
11-23-2021 06:46 - edited 11-23-2021 09:47
UPDATE: I found the solution. It's technically the same answer as this one here but they changed the way we get to the Apps in a recent update. You now have to choose the "Gallery" tile, and THEN choose the Apps tab at the top of that window, which will take you to the apps, where you can choose your individual app settings from there. The "Apps" tile no longer exists.
I have this same issue (with the exception that the weather app on my Sense is showing Celsius and I want it to say Fahrenheit). However, when I try to follow these instructions, it appears I don't have "Apps" in my Sense menu as indicated in these instructions.
I do have "Fahrenheit" selected in the unit section of my Fitbit app, yet the weather display on my Sense still shows Celsius.
Any ideas?
11-23-2021 09:08
11-23-2021 09:08
This is what's happening to mine as well. My app says in settings F but my sense is showing C. When I go to "Apps" in settings like described above, I don't have "my apps" as a choice.
12:12
10:22
11-23-2021
12:12
10:22
@Splunky123 - the tile is now called Gallery, no longer an Apps tile.
The weather units don't follow the settings of the Fitbit app and have to be set separately.
12-30-2021 20:13
12-30-2021 20:13
Finally... Thank you.... this needs put at the top. Was getting so frustrated not seeing "app" like all the other answers
01-15-2022 14:54
01-15-2022 14:54
THANK YOU!!! I have spent the last several hours trying to figure this out. My watch was stuck on celcius but my app said farenheit. I used this method you suggested and BAM! FIXED!!! THANK YOU AGAIN!
01-15-2022 15:17
01-15-2022 15:17
I can't get my galley tile to open up. It keeps saying retry no internet connection which is not true.
Best Answer01-15-2022 20:52
01-15-2022 20:52
Hi @cschloegl - a no internet connection is generally a phone issue, see No internet connection
Best Answer01-27-2022 09:13
01-27-2022 09:13
Thanks. This was driving me crazy
07-14-2022 08:43
07-14-2022 08:43
What a relief! I’d been trying to set it the old way, and was resigned to remembering Celsius temperatures.
09-05-2022 15:52
09-05-2022 15:52
Mine is showing the same. I've tried all the troubleshooting, but nothing...
Best Answer09-05-2022 19:37
09-05-2022 19:37
Hi @Perrycan - try this link How to change Temperature - for Weather, Centigrade - Fahrenheit, Sense
Best Answer11-06-2022 13:02
11-06-2022 13:02
I can go to my profile picture but do not see anything about APPS when I tap onto Sense. Any other ideas about changing from Celcius to Fernheiht?
Best Answer01-06-2023 08:57
01-06-2023 08:57
I found that my Fitbit Sense did not have the Apps option but it did have Gallery. The navigation steps for my Sense is similar to this post but a little different. I had to click on my profile ICON, Sense, Gallery and then scroll through the Apps until I reached the Weather App. Click on the Weather app, click on Settings and was able to select Fahrenheit or Celsius under Unit. Then click on Done.
