03-14-2022
08:22
10:46
LizzyFitbit
03-14-2022
08:22
10:46
LizzyFitbit
sleep data has been off by 1 hour since switch to DST.
Sense shows correct time.
Sleep data is showing i went to sleep at an hour latter than i did, resulting in
much lower sleep time and quality score.
Best Answer03-15-2022 02:28
03-15-2022 02:28
I have the Luxe & same issue....so there is obviously a running issue with their App. From a search of this issue it seems like this is a problem going back YEARS! Come on Fitbit folks! People have been complaining about this at least since 2016. Don't you think you should REALLY get on the ball and sic your app developers to remedy this ongoing problem???
Best Answer03-15-2022 04:53 - edited 03-15-2022 04:55
@royalle Yeah I had a daylight savings issue but I got more time. I woke up at 9:15am (Daylight savings) and Fitbit said 10:15am. I just manually adjusted it to 8:15am.
One of the first Google search results came up with this thread from 2017:
You would think they would have this fixed after all this time. So just keep in mind in the fall we'll have to add an hour.
