08-06-2022 14:28
08-06-2022 14:28
Still not happy with the sense sleep tracker!! Have done every suggestions, still get the same result.
Here's a comparison between a cheap one and my sense, done on the same day.
08-06-2022 15:11
08-06-2022 15:11
hello
sleep tracking on any device ( unless you're hooked up to all kind of tracking device under strict lab settings} will always be different i see the cheaper model that you have recorded your sleep on has your sleep in a more "simple" breakdown
Sense for me personally gives a more accurate and detailed analytics into not only how long i slept but how i slept my heart rate oxygen etc
i think thats why you are getting different readings on the devices
08-06-2022 15:32
08-06-2022 15:32
Hi
Not that much difference !!
I've worn them both together as per screen shots, worn them separate not once has the sence worked accurately
08-10-2022 01:29
08-10-2022 01:29
Hi again
I love all the other features, i just want the sense sleep feature to work accurately.
My sleep period is- 10.30am to 7.00am, it never starts on time it's always the next day- am
It actually tracks and shows my nana naps- Pm and how long it was
08-10-2022 03:13
08-10-2022 03:13
Hi, @Nandad, you may find this article useful How do I track my sleep with my Fitbit device? which explains the details of Fitbit's data. Perhaps you can provide similar information about your other tracker, it's not possible to say your "Sense" is not accurate if you do not tell us how you made the comparison.
Cheers
Gr4ndp4 | UK
08-10-2022 05:07
08-10-2022 05:07
Hi
I jjjjust want it to the job will I'm a sleep not half way through my sleep.
I brought the cheap one while a new one was coming as a replacement, and it has miss a beat re time i go to bed and get up.
I have the same settings as my wife one and hers always works.
Technology articles doesn't interest me because I'm dyslexic seeing a human would work for me, it sould work like my wifes!!!!!!
Terry
08-11-2022 16:14 - edited 08-11-2022 16:16
Mine started doing the same thing - though not always with short naps (sometimes extending it into one or two long sleeps with large red blocks of wakeful periods in them) around the time of the firmware update. I contacted Fitbit Help about it before editing one of my records so they could see and it even showed 1hr and 26 minutes of sleep while I had also accrued 141 steps at the same time - and not from sleepwalking. I was told they would bump it to "Tier Two" and I would "receive an email" but in the last 18months+ I have never ONCE received an email, phone call, or anything from actual "Tier Two" which I am beginning to doubt even exists...
08-11-2022 18:58
08-11-2022 18:58
Hi
They replaced mine, and also said the same re sending a email 😡
The replacement is no better.
Terry
