03-02-2021 19:29
03-02-2021 19:29
I have had my fitbit sense for 5 days. Generally I have things working with the exception of SpO2. I have worn it for every night since I got it. Measures my sleep, heart rate, but I get no data for O2. I have tried several clock faces (not sure why that should be the problem because I would think all the clock face does is display date not calculate it). I don't see it in the health metrics in the app. I get my breathing rate, heart rate variability, skin temperature, but no SpO2 data. What am I missing? Is there some other app that I need to install? I have seen some recommendations that suggest it is a cache problem and you should clear the cache and then force stop the app and then sign on to the app again. This didn't help. Should I delete the app and re-install the app?
Best Answer03-02-2021 20:24 - edited 03-02-2021 20:41
You don't need a clock face for a Sense to register SpO2, its done by the SpO2 tracker app, you can check its there.
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Apps Tile MY APPS Click on SpO2 Tracker Verify all permissions are on |
Any problems in the Fitbit App can be cleared
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit shutdown [though it doesn't seem to fully] Log back in to the Fitbit app
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
For IOS uninstall/reinstall the Fitbit App, and redo the Notifications setup.
A phone reboot would be a sensible thing to do after.
Best Answer03-07-2021 09:18
03-07-2021 09:18
I have done all of the suggested things to do, Like clear the cache force at shutdown and then do a log back in. I even tried deleting Fib from my phone and redownloading. and rebooted my phone. I have tried several different band looseness. I have only had one reading recorded in the health metrics and that was on the 5th. I have had nothing since. I have no idea what to do next.
