03-11-2021
04:56
04:25
03-11-2021
04:56
04:25
Region: USA
I have the Sp02 sensor app installed, and a watch face installed to use it. Every few days, the watch face will revert back to the default and I cannot select the Sp02 waveform face because it is not available for me. If I check "myapps" I see the Sp02 sensor app, but get a message that it is not available in my region.
Why am I sometimes not able to use the function and sometimes able to use it, and what can I do about this?
03-13-2021 04:35 - edited 04-26-2024 06:03
Hi there @Skalad, welcome to the Community Forums. Thanks for sharing the details about the issue with your Sense.
As well as your region selected, are you also located in the USA now? Please make sure you've followed the directions provided here How do I track blood oxygen saturation (SpO2) with my Fitbit device? to properly install the SpO2 clock face.
In addition, also check that you've set your correct country in the Fitbit app:
I've moved your post to the Sense board for organization purposes.
Best Answer03-13-2021 04:35 - edited 04-26-2024 06:03
Best Answer03-13-2021 10:12
03-13-2021 10:12
I'll see if that helps. I just don't see why sometimes I have access to it and other times it is not available in my region. For what it's worth, I have always been located in the USA.
