07-07-2022 15:06
07-07-2022 15:06
When I swim in the morning, it is exercise and back/forth in the pool for 20-30 little laps. I set the water lock for this and it works fine - bit tricky to turn off but not bad and it logs how far I swam along with the laps. My question though is about general swimming - I often garden and in summer get hot, so drop into the pool for a few minutes to cool off. Should I put the water lock on or is it like the Versa which is waterproof?
My other question is the Exercise tab - if I click that to workout and do the workout from the iPad, it logged it twice. Should I just forget the watch when I do the workout on another device?
I also use the 'outdoor' tab for mowing/general gardening. I am not sure what others use it for but wonder if this is what the tab was meant for.
I am loving getting to know that new Fitbit.
Kate
Best Answer07-09-2022 07:20
07-09-2022 07:20
Hi, @katecopsey , your "Sense is water-resistant up to 50M
Environmental conditions
| Operating temperature | 14° to 113° F |
| Non-operating temperature | -4° to 14° F 113° to 140°F |
| Charging temperature | 32° to 95° F (0° to 35° C) |
| Water resistance | Water resistant up to 50 meters |
| Humidity range | While Fitbit Sense can operate in humidity conditions between 0% and 100%, we recommend not operating in conditions over 60% for prolonged periods of time. |
| Maximum operating altitude | 28,000 feet (8,534 m) |
You may also find this article useful Can I swim or shower with my Fitbit device?
I hope this helps.
Cheers
Gr4ndp4 | UK
07-07-2022 21:26
07-07-2022 21:26
Hi @katecopsey - the idea of the water lock is only to stop accidental actions being performed by the water passing over the screen or button.
07-09-2022 03:38
07-09-2022 03:38
So the Sense is waterproof as an item and I can take a quick cool down dip without damaging it and without the water lock on? My concern was that the screen would be damaged by water if the lock was not on. From what you are saying that is not going to happen.
Thanks
03:42
07:34
07-09-2022
03:42
07:34
@katecopsey - yes, however some watches let water in regardless as the seals aren't reliable.
If it is under warranty you can get it replaced but I wouldn't risk getting it wet after that as the seals degrade over time too.
Check in the forums for numerous reports of this.
Best Answer07-09-2022 05:04
07-09-2022 05:04
Thanks for that information. I think I will just strip it off and dump it on the table along with the eye glasses and other non waterproof 'stuff'.
07-09-2022 07:20
I hope this helps.
Cheers
Gr4ndp4 | UK
07-09-2022
08:43
07:34
07-09-2022
08:43
07:34
@Gr4ndp4 - sorry that's just publicity - like many many people have posted in the forums their watch died after getting wet, as did mine, so its better to be safe and not use it in water especially after the warranty has ended or you may end up with no watch.
Mine only got wet, not even to one metre under water and failed.
07-09-2022 09:27 - edited 07-09-2022 09:29
Hi @Guy_ yet I swim 3000 meters 6 days a week for 90 minutes (2000 on Saturday - rest day) for the last 18 months without a problem.
Cheers
Gr4ndp4 | UK
07-09-2022 10:03
07-09-2022 10:03
Hi @LindaWashington - unfortunately as a new user it doesn't seem that you can send personal messages.
Best Answer07-09-2022 11:56
07-09-2022 11:56
Hi @LindaWashington these are the community forums where people post in the public area to ask questions or discuss their Fitbits. You don't need to take something private. In fact, that is generally a red flag when someone wants to go private on any forum, isn't it? If you need something, feel free to post it in the forums and someone will find a way to help you.
07-11-2022 05:32
07-11-2022 05:32
Like @Gr4ndp4, I swim in my chlorine pool almost every single day. I don't swim as many meters as @Gr4ndp4 does, but I'm in my pool with my Sense and also shower with it daily. I haven't had any issues with it at all.
07-11-2022 10:22
07-11-2022 10:22
I am a bit concerned about the humidity factor - I hope outside dries up enough for me to mow but the temp 80f and 82% humidity! Yep I am in sauna-land aka South Carolina and this is typical summer weather, so I hope it survives the summer down here.
Best Answer07-11-2022 11:56
07-11-2022 11:56
@katecopsey I am in the Florida panhandle. It's 70% humidity or more every single day. This morning I went for a run and it was 98% humidity. I would not worry about humidity.
Best Answer11-12-2022 10:24
11-12-2022 10:24
Hi there, it seems like you could answer my question about the Charge 5:
I have a Charge 3 that needs to be replaced now. I have been using Fitbits for about 5 years to track swimming. In my opinion they have gotten a lot better over that time, but I just track laps and it's great for that (as long as I remember to add in my kicking laps).
What I really want is the same features I have now but with a brighter display. Will the Charge 5 do that for me, or is there a better choice now for swimmers?
