11-16-2021
16:28
10:29
LizzyFitbit
11-16-2021
16:28
10:29
LizzyFitbit
Hi,
I usually switch between the sense and versa 2 while one is charging and up until today, I always had to setup a new device for the switch to work, which is normal, but today I was going to switch from the versa 2 to sense and was surprise to find out that they are both still connected , so I did not have to do a new setup. Is that a new feature or did I just find a bug?
Moderator Edit: Formatting
11-17-2021 02:45
11-17-2021 02:45
Hi, @gsilva3891 - interesting, it is probably a bug, post back if it works with both connected.
An alternate method is to have 2 accounts with one watch attached to each.
Then it simply involves a logout and login to switch between them.
Also consider the free SimpleCheckUp app. This will tell you when you last synced on the watch directly and if its connecting to the Fitbit App and so you will be able to see exactly the outcome.
