Text and phone call notifications.
It seems as though I have a limit on how many notifications I can get. If I clear all, then I receive more. Is there a way to automatically drop messages so new ones can sync?
2 REPLIES 2
Hi @Sjmitchell,
As far as I know, no there is no limit and no the is no way to automatically drop the messages.  Just pull down from the main screen on your Sense and select "Clear All" and it will get rid of all the current notifications you have on the watch.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
Hi @Sjmitchell  -  it should happen automatically. When you respond to a notification and it is cleared on the phone it should clear it from the watch automatically.
If it's not doing that check your syncing is working properly. Why won't my Fitbit device sync?
If it isn't syncing [ or the two devices can't connect when needed ] your notifications on the watch will not get cleared automatically.
