It depends, normally syncing the device with your Fitbit App should get the correct time, depending on the options you have chosen for the phone and the App [eg. timezone and location and time source]. Sometimes it may be necessary to restart the watch [and possibly also phone] and sync.
If you want to switch to a different display you can change clock faces, or if you have Always on enabled, you can push the button.
It just depends on what you want to change.
See also time setting questions
Best AnswerWhat is wrong with the time. This would be a key with knowing how to answer.
If it did not change with DST then open the fitbit app so that a sync will be forced.
