02-08-2023 11:04
02-08-2023 11:04
Hi, I recently noticed that the Timer app immediately crashes when I start it on my Fitbit Sense. When I tap the Timer app, it starts loading and displays the Timer icon in the center of the screen, and then it simply disappears and is no longer running. I have used the Timer app successfully in the past, but it's been awhile since my last use so I don't know when it stopped working.
What I've tried:
Any other ideas/recommendations? Is this working for other people?
Best Answer02-08-2023 20:19
02-08-2023 20:19
Hi @SHaase - it seems it's an OS fault.
Can you chat via the Fitbit App, click profile photo, Help & support, Contact Customer support. They can take you through a lengthy factory reset and reinstallation.
Or you can do it from the watch Settings, about menu, but wait for several minutes for it to complete before setting it up again.
There are other timer apps in the Gallery if you just want a quick timer and the rest of your watch is working.
If you do a factory reset first note the names of your clocks and apps for easy reinstalling afterwards.
02-08-2023 20:19
02-08-2023 20:19
02-10-2023 11:05
02-10-2023 11:05
sigh. I was hoping to not have to do a factory reset, but went ahead with it since there was no other feedback. The factory reset did resolve the issue.
Thanks Guy_
