09-02-2022 15:31
09-02-2022 15:31
Is there a way to lock the timer on the watch face so it’s always there when I look?
09-03-2022 06:41 - edited 09-03-2022 06:45
Hi, @Mannbrad, welcome, On your "Sense" from the clock screen>settings>swipe up to "Display">swipe up to "always on display" and set the slider to the "on" position. This may not work with some clock faces, you will need to change the clock face if necessary. In the app on your phone touch your icon in the top left>Sense tile>Gallery>Clocks tab>swipe up looking for "Always on display". There are many to choose from.
Alternatively, if you only want to view a timer already running on your "Sense" set the screen wake to motion & button. turning your wrist will illuminate the display.
I hope this helps.
Cheers
Gr4ndp4 | UK
I hope this helps.
Cheers
Gr4ndp4 | UK
09-03-2022 07:22
09-03-2022 07:22
Thanks!! That worked
09-03-2022
12:02
10:23
09-03-2022
12:02
10:23
Hi @Mannbrad - another solution is to use SimpleTimer - it has the option to toggle the display to stay on while timing, along with other options, such as remembering 4 presets, showing the time, as well as timer, auto start and repeat.
It will also run in background to the SimpleClockPro clock face which means you can start or check a timer directly from the watch face.
09-03-2022 18:22
09-03-2022 18:22
