12-18-2020 00:57
12-18-2020 00:57
Are there any plans to have an 'ultra dim' screen option for the Sense?
Im finding the screen's brightness can wake me/partner up just through normal movement in bed by, e.g. turning over causing my arm to mimic the raising movement.
Another use case would be in other areas where darkness should be maintained - cinemas etc.
It would be be good to have options to ultra-dim manually, as per the current dim/normal/bright selection, plus scheduled at certain times, and even using sleep detection at night.
Best Answer12-18-2020 05:18
12-18-2020 05:18
@cpgod, have you used the Sleep Mode option to dim the display? If not, try it. Swipe to the screen to the left, tap on the Moon icon to enable Sleep Mode, tap on it again to disable the Sleep Mode.
Best Answer12-18-2020 05:32
12-18-2020 05:32
Thanks @USAF-Larry - forgot about that.
However, Sleep mode is not quite there for all my use cases though - the dim screen is still pretty bright in a cinema and it doesnt automatically kick in at the start of my sleep schedule, despite it allegedly stopping at the end of it.
