02-23-2025 07:14 - edited 04-06-2025 01:06
There is an issue with the step counting as shown here, with the dated Core Stats.
At 15:38 the watch was indicating an erroneous 13,256 steps
After a sync it was showing a more accurate 8,536 steps
How or why this bug has appeared is unknown. It is due to improper syncing/server processing.
There is nothing a user can do to fix this bug, any attempts could make matters worse and be a waste of time.
If the watch is not connected to the Fitbit App, by closing the app [often not possible] or better by turning off Bluetooth, and the steps are correct it would confirm that as the cause.
For Versa/Sense users [not Versa 4 or Sense 2], the SimpleCheckUp app [first screen] might help to know on the watch when the watch last synced.
When turning on Bluetooth again, it is necessary to manual sync a few times to get the correct steps to show.
This bug is NOT related to any watch firmware update or Fitbit App update and applies to all phone and watch types. There will be no update issued to fix it.
Steps counting bug - Update March 20th
It seems this is still not entirely stable and Google may still be introducing changes.
Small adjustments can appear when auto syncing [every 15 minutes about depending on connectivity] or even manual syncing randomly.
Steps counting bug - Update March 19th
After some more testing and in the absence of any official information from Google - the app finally appears to sync correctly without any unwanted adjustments.
Of note, no action by the user was/is necessary for the syncing to be correct, as the error was only at the Google end.
Steps counting bug - Update March 17th
Some people still noticed minor adjustments to the watch steps when syncing, meaning the problem is still not fully fixed.
Steps counting bug - Update April 7th:
The ensuing minor steps adjusting bug that was still prevalent seems also fixed now.
Steps counting bug - Update March 13th:
This may finally be fixed - check steps on your device and manually sync, If the app then shows the same for you it is fixed. However some minor adjustments still seem to occur.
Stress Management Score - Update March 7th:
The missing Stress Management Score that affected all user types [regular or premium] is supposedly fixed now without any user intervention. Though the missing history is not recovered.
For those still not getting it yet please make a separate post/investigation.
03-12-2025 22:27 - edited 04-06-2025 01:07
Hi all,Steps counting bug - Update April 7th:
Some people notice minor adjustments to the watch steps when syncing, meaning the problem is still not fully fixed.
Update March 13th: Initial partial fix
Not seen any official response from Google yet confirming a resolution has been applied for everyone, but there is hope the bug may finally be fixed!
To check, observe steps on your device and manually sync, If the app then updates to show the same number of steps, then for you it is fixed.
A better test can be done by leaving Bluetooth off for a while and then do the above, and note the app changes, from the last synced steps to the new steps that is showing on your device and remains , even if you sync again.
02-22-2025 10:04
02-22-2025 10:04
A few imes I have thought that the number of steps showing on my Sense had gone down. Today it buzed to tell me I had completed my 10,000 steps but an hour later it showed 9,000 steps. Does anybody know what is going on?
02-22-2025 10:15
02-22-2025 10:15
Exactly the same here. Has now happened each day over the past 3 days 😞
02-22-2025 15:20
02-22-2025 15:20
Mine started yesterday and it will randomly and instantly gain or lose steps, usually 1,000 to 2.000 at a time. I started keeping track of it and it has done it at least 15 times today alone. I tried restarting it the watch, but it made no difference.
02-22-2025 15:57
02-22-2025 15:57
Came here for the same problem. Was over 15,000 steps today now it’s only showing 8,000? And in my activity it has nothing for the times I was walking. Was hoping I would find some answers here.
02-22-2025 18:15
02-22-2025 18:15
My Sense has been acting wonky fora couple days too. Yesterday it told me I hit 10,000, but my phone app said 8,000+. Refreshed my phone and it told me I had 17,000 + steps. Refreshed again, then both the phone app and Sense were back to 8,000. 🤷:female_sign:
The Firmware update has also screwed with my battery life as well. It only lasts about 3 days. What’s up Google Fitbit???
02-23-2025 06:14
02-23-2025 06:14
Our watches are not loosing steps, they are randomly adding steps. I have been able to get mine to go back to a more believable step count by syncing it to the Fitbit app. However syncing multiple times is necessary.
02-23-2025 07:16
                              02-23-2025 07:16
Hi All, see the link unreliable step counting bug
 Best Answer02-23-2025 07:54
02-23-2025 07:54
Thanks. I appreciate the help. Any thoughts on the firmware battery issue?
02-23-2025 07:58
02-23-2025 07:58
Yep, This started about a week ago. I lose then gain thousands of steps in minutes. Shutting off the phone or turning off Bluetooth has stopped the problem. Can't wait to see what happens when I turn Bluetooth back on at the end of the day... Please fix the App/Server problem Fitbit.
02-23-2025 08:28
02-23-2025 08:28
Thank you so much, I will try this
02-23-2025 08:29
02-23-2025 08:29
Thank you for finding that out
02-23-2025 09:17
02-23-2025 09:17
So it's fixed? I did so many things yesterday with customer service. Phone stuff, watch stuff and app stuff. Personally I think it's a watch problem.
02-23-2025 10:47
02-23-2025 10:47
It's a workaround, not a fix. Have you tried shutting off your Bluetooth? If you do and the problem goes away, then it's not the watch, it's a Fitbit App syncing problem.
02-23-2025 11:56
02-23-2025 11:56
I keep losing steps. I was at 7,000 then it increases to 8,000 then decreased to just under 6,000. I’m concerned it’s syncing elsewhere but I’ve checked and double checked and turned off Apple health. It’s typically after I’ve put in “workout” mode on my watch.
02-23-2025 12:07
02-23-2025 12:07
This started on Friday for me and I thought for a second it was just me, but has happened every day since, hopefully they can get this ironed out quickly. Going to take the suggestion of shutting off the bluetooth for tomorrow's workout as I agree it's a sync issue of some type.
02-23-2025 12:20
02-23-2025 12:20
I got the same issue recently. The streps reduced, it told me I have reached 10k but half hour later my steps became 9K. And the battery seems only lasting for one day rather than 3-4 days in the past. What’s going on recently?
02-23-2025 13:30
02-23-2025 13:30
Hi, after I completed the last firmware update my sense has not been counting steps correctly. Noticed that after 6000 steps it jumps drastically by 2000+ steps. I keep a close count on my steps using fitbit so if the basic function is not working, that is not very useful. Can you please assist so the step count works gain. Thanks
02-23-2025 14:18
02-23-2025 14:18
Ever since the forced firmware update, this has been an issue. Quite frustrating. Anytime I refresh the app my steps change and even odder, the watch matches whatever the refresh says.
Also, the battery is super flaky. This firmware update is a mess.
Hope this is fixed soon.
02-23-2025 14:20 - edited 02-23-2025 14:22
Thanks for sharing this Guy. Luckily I have not noticed any erratic step counting (yet).
Hi @eculbertson For the battery comment you should post in one of the dozens of posts related to the new battery update. There is nothing to "fix" with that. If your watch has a defective battery that is why it received the update and the limited battery is the fix (to prevent overheating).
