02-23-2025 07:14 - edited 04-06-2025 01:06
There is an issue with the step counting as shown here, with the dated Core Stats.
At 15:38 the watch was indicating an erroneous 13,256 steps
After a sync it was showing a more accurate 8,536 steps
How or why this bug has appeared is unknown. It is due to improper syncing/server processing.
There is nothing a user can do to fix this bug, any attempts could make matters worse and be a waste of time.
If the watch is not connected to the Fitbit App, by closing the app [often not possible] or better by turning off Bluetooth, and the steps are correct it would confirm that as the cause.
For Versa/Sense users [not Versa 4 or Sense 2], the SimpleCheckUp app [first screen] might help to know on the watch when the watch last synced.
When turning on Bluetooth again, it is necessary to manual sync a few times to get the correct steps to show.
This bug is NOT related to any watch firmware update or Fitbit App update and applies to all phone and watch types. There will be no update issued to fix it.
Steps counting bug - Update March 20th
It seems this is still not entirely stable and Google may still be introducing changes.
Small adjustments can appear when auto syncing [every 15 minutes about depending on connectivity] or even manual syncing randomly.
Steps counting bug - Update March 19th
After some more testing and in the absence of any official information from Google - the app finally appears to sync correctly without any unwanted adjustments.
Of note, no action by the user was/is necessary for the syncing to be correct, as the error was only at the Google end.
Steps counting bug - Update March 17th
Some people still noticed minor adjustments to the watch steps when syncing, meaning the problem is still not fully fixed.
Steps counting bug - Update April 7th:
The ensuing minor steps adjusting bug that was still prevalent seems also fixed now.
Steps counting bug - Update March 13th:
This may finally be fixed - check steps on your device and manually sync, If the app then shows the same for you it is fixed. However some minor adjustments still seem to occur.
Stress Management Score - Update March 7th:
The missing Stress Management Score that affected all user types [regular or premium] is supposedly fixed now without any user intervention. Though the missing history is not recovered.
For those still not getting it yet please make a separate post/investigation.
04-02-2025 06:46
04-02-2025 06:46
04-05-2025 13:55
04-05-2025 13:55
04-05-2025 21:49
04-05-2025 21:49
Hi @Sdhb - thanks for asking, I still notice a slight modification in steps on syncing sometimes.
I use the SimpleCheckUp app to know when there will be an automatic sync which happens every 15 minutes and check the steps on the watch just before the next auto sync and often they change.
If you check in the Fitbit App itself it may be too late because it does an immediate sync, though sometimes you can still see the modification.
While it isn't the swings of thousands of steps we had before it is still not correct to adjust watch steps in this way as it can alter other metrics over time.
04-06-2025 01:53
04-06-2025 14:25
04-06-2025 14:25
04-21-2025 13:40
04-21-2025 13:40
Exactly!
I actually never had issues like this before. I run a charge 6 with my iphone 16 pro and today while I was working out in the gym I noticed my steps stopped counting live while I was on the stairmaster. Later tonight I found that the steps on my app were showing 500ish steps more than on my watch. I tried re- pairing, restarted my devices, added the app. Nothing worked. I am on a 85 days score streak of 10k + a day and this is unacceptable from Google. They always manage to screw things up.
04-22-2025 05:54
04-22-2025 05:54
04-22-2025 19:02
04-22-2025 19:02
Mine just started doing it after a recent update.. it seems like it would just restart the next day and be fine, but it doesn’t end up that way.
Any tips/info will be helpful! thanks
04-23-2025 13:28
04-23-2025 13:28
It seems that when they do an update I start having trouble again. And here we are again. I’m on version 4.41 up from 4.39. So today problems again. I turned phone off and back on. I removed app and put it back on. Turned watch off and on. It miss counted on my phone. I pulled down on the screen to refresh a couple of times until my phone agreed with my watch. Had to do that a few other times. Then it was okay. I did notice I was having trouble syncing it before I took those steps. This has been very frustrating.
04-24-2025 02:57
04-24-2025 02:57
I have same issue all the time. My watch send me notification of steps. When I sync watch, it posts under the notification amount. If I pull down several times, it goes up and down and up and down. I just settle on the amount which doesn’t change and seems reasonable.
05-01-2025 10:51
05-01-2025 10:51
I'm still having this problem, why is this not fixed yet
05-03-2025 08:20
05-03-2025 08:20
05-03-2025 08:36
05-03-2025 08:36
To be fair, it happened to me just one day and the next everything was fine again and havent had any issues again. Running on all latest software possible 🙂
05-03-2025
08:40
06:52
MarioSFitbit
05-03-2025
08:40
06:52
MarioSFitbit
Lucky, I'm still experiencing the same issue with steps on my sense 2 and
Charge 6. Any one else?
Ya but they need to fix this, this is Fitbits key feature
Moderator edit - Merged messages
05-04-2025 11:19
05-04-2025 11:19
05-04-2025 12:04
05-04-2025 12:04
05-04-2025 12:20
05-04-2025 12:20
