Unreliable step counting bug
ANSWERED
There is an issue with the step counting as shown here, with the dated Core Stats.
At 15:38 the watch was indicating an erroneous 13,256 steps
After a sync it was showing a more accurate 8,536 steps
How or why this bug has appeared is unknown. It is due to improper syncing/server processing.
There is nothing a user can do to fix this bug, any attempts could make matters worse and be a waste of time.
If the watch is not connected to the Fitbit App, by closing the app [often not possible] or better by turning off Bluetooth, and the steps are correct it would confirm that as the cause.
For Versa/Sense users [not Versa 4 or Sense 2], the SimpleCheckUp app [first screen] might help to know on the watch when the watch last synced.
When turning on Bluetooth again, it is necessary to manual sync a few times to get the correct steps to show.
This bug is NOT related to any watch firmware update or Fitbit App update and applies to all phone and watch types. There will be no update issued to fix it.
Steps counting bug - Update March 20th
It seems this is still not entirely stable and Google may still be introducing changes.
Small adjustments can appear when auto syncing [every 15 minutes about depending on connectivity] or even manual syncing randomly.
Steps counting bug - Update March 19th
After some more testing and in the absence of any official information from Google - the app finally appears to sync correctly without any unwanted adjustments.
Of note, no action by the user was/is necessary for the syncing to be correct, as the error was only at the Google end.
Steps counting bug - Update March 17th
Some people still noticed minor adjustments to the watch steps when syncing, meaning the problem is still not fully fixed.
Steps counting bug - Update April 7th:
The ensuing minor steps adjusting bug that was still prevalent seems also fixed now.
Steps counting bug - Update March 13th:
This may finally be fixed - check steps on your device and manually sync, If the app then shows the same for you it is fixed. However some minor adjustments still seem to occur.
Stress Management Score - Update March 7th:
The missing Stress Management Score that affected all user types [regular or premium] is supposedly fixed now without any user intervention. Though the missing history is not recovered.
For those still not getting it yet please make a separate post/investigation.
316 REPLIES 316
Same. I’m so over it. Seems to be a thing since I started with the google addition
Done. Didn’t work
Sent from my Healthy iPhone
I have had mine for a long time and up until now I have had no issues with
it. If it's something that will continue to fix itself that's one thing but
if it gets worse I will need to update it. I got it over 4 years ago.
I did a factory reset night before last and it did a watch update and seemed ok but then I had a quiet day. This morning there was a Fitbit app update from the Android play store and tested by walking my usual route which is about 10K steps on average.. I was showing well over 15k when I got home.. hit sync a few times and it shrunk to around 10K.
This is getting to be pretty useless for trying to walk to meet goals and never knowing what you will end up with at the end of the day. I started the Fitbit  journey April 3, 2014 and since google took over I see all the things I grew to love get taken away like the Fitbit Bingo, Step Challenges. Now it seems  that after 11 years of loyalty to be useless as a device to track my fitness..  I may need pull my McDonalds Step Counter off the shelf and use it instead
I think we are all with you now. Taken a device that started out ok and in my 11 years seem to want to drive us to other products
I think this was my last fitbit
A weird thing happened this morning, the main steps at top of today are locked at my morning steps.  If you move to individual steps, it’s my first 5555 steps notification which I sync to get my oxygen level.
As of today it is not fixed 3.8.25
Hi all.  I’ve been following this thread as I’ve had the same issues.  I’ve done all the things recommended here and elsewhere to no avail.
I chatted with them a couple days ago and they said they are aware of the issue and are working on it.  Keep watching for app updates and keep it up to date.  IOW, they said there is nothing we can do to fix it ourselves other than ensuring we update the app when updates are available.
4.38 their newest version is out.But no avail.There is still a problem with losing your steps!!
I'm having similar problem.  My sense watch show about 3000 steps higher than I anticipated.  Then sit for an hour & I have 3000 fewer steps.  Ssomething is draining the phone battery now.
I see lots of people with same problem but NO fix!  How do you fix this.?
Yes my steps keep doubling then going back to accurate. Obviously I know it's not my Fitbit sense so definitely a bug in the works. Does go back to accurate but slightly annoying. When getting the "yay you've met your goal" then of course realise...em that's not right 😀
Although annoyed I am glad to see I am not the only person with this issue.  I woke up this morning and it said I had over 7,000 steps.   I am really trying to improve my exercise and this is most annoying.  I've had it not even count steps over the past 3 weeks. I suspected it and did a check and yep.  20 min on an eliptical and nothing... really fitbit.    I hate to say it but I will probably be moving to another platform.. This has been going on too long now.
Ach that's a shame. Hope they fix it soon and you can happily keep your Fitbit. Mine at least doubles the steps then sync and they go back to accurate.
Has there been any feedback from Google/Fitbit about this? It’s really annoying, some days I reach my target step count 3 times!
Haven't heard anything as yet.
😟 shame
I agree, but what can you do?
Our watches indicated different start times for our activity today, so we tried to set it to where we wanted it.
The Sense on the App - NOPE - I'll set it where ever I want to.  How about 11 am until 10 PM?  Change it, save it, NOPE, 10 am until 11 pm.
Try multiple times, same effect.  How long FitBit does it take to fix a "server issue?"  Can we get an answer to that?
I'm going out for dinner tonight.  Best Buy is nearby.  Maybe it's time to say farewell to the FitBit brand (which means Google Watch too) and look somewhere else?
There's a bug if you switched to daylight savings where things can't be changed or are wrong, but should be ok on Monday.
I wished they have a fitbit contact so we can get the real answer instead
of just whining about the problems.
At least I now know it’s not just me…😐
