There is an issue with the step counting as shown here, with the dated Core Stats.
At 15:38 the watch was indicating an erroneous 13,256 steps
After a sync it was showing a more accurate 8,536 steps
How or why this bug has appeared is unknown. It is due to improper syncing/server processing.
There is nothing a user can do to fix this bug, any attempts could make matters worse and be a waste of time.
If the watch is not connected to the Fitbit App, by closing the app [often not possible] or better by turning off Bluetooth, and the steps are correct it would confirm that as the cause.
For Versa/Sense users [not Versa 4 or Sense 2], the SimpleCheckUp app [first screen] might help to know on the watch when the watch last synced.
When turning on Bluetooth again, it is necessary to manual sync a few times to get the correct steps to show.
This bug is NOT related to any watch firmware update or Fitbit App update and applies to all phone and watch types. There will be no update issued to fix it.
Steps counting bug - Update March 20th
It seems this is still not entirely stable and Google may still be introducing changes.
Small adjustments can appear when auto syncing [every 15 minutes about depending on connectivity] or even manual syncing randomly.
Steps counting bug - Update March 19th
After some more testing and in the absence of any official information from Google - the app finally appears to sync correctly without any unwanted adjustments.
Of note, no action by the user was/is necessary for the syncing to be correct, as the error was only at the Google end.
Steps counting bug - Update March 17th
Some people still noticed minor adjustments to the watch steps when syncing, meaning the problem is still not fully fixed.
Steps counting bug - Update April 7th:
The ensuing minor steps adjusting bug that was still prevalent seems also fixed now.
Steps counting bug - Update March 13th:
This may finally be fixed - check steps on your device and manually sync, If the app then shows the same for you it is fixed. However some minor adjustments still seem to occur.
Stress Management Score - Update March 7th:
The missing Stress Management Score that affected all user types [regular or premium] is supposedly fixed now without any user intervention. Though the missing history is not recovered.
For those still not getting it yet please make a separate post/investigation.
I am really disappointed in fitbit. I really liked the sense 2 and the app but am now moving on. I looked at both the pixel 3 and galaxy watch 7 and ended up buying the galaxy watch 7 44mm. Other than the need to charge the galaxy watch more often it looks like a much better watch with hopefully better support. Time will tell....
Thanks, mine has been doing this since last year around the time of google changeover funnily enough. But the on wrist device is accurate and the app just keeps reducing steps overnight in this case. Resyncing, turning Bluetooth off and on again, logging out shutting down a turning everything thing back on again only sometimes results in a temporary fix. I cannot find a way of unpairing my app with my old inspire, it’s not as per the previous suggestions. I think it’s time for a change if Fitbit are not putting in a fix on this.
Best Answerre the Step Counting Bug
I find I do get to the correct step count after several manual re-syncs. If I don't manually re-sync, by bedtime it has corrected itself.
I go for a daily walk along the route I have walked many times before. By days end my steps end up being within what I consider to be normal range.
It's annoying, especially when I'm hoping to get a calorie count before dinner so I know if I can have a bit of dessert afterwards, but completely livable temporarily imho. LOL.
Best AnswerSeriously, I actually tried out a Samsung watch and found it not as good as fitbit and switched back to the versa 3 when it was new. Since I think I will be switching from a Samsung phone to an iPhone soon I might make the switch to an Apple watch. Which is a shame because I have been an arden fitbit wearer since the beginning!
I looked at my step count and ordered a burger as a treat. After I synced and the step count updated, I could only afford the lettuce from my step budget. Daam shame I tell ya.
First, the UI disappointment and now, this. If Google does not up it's game soon, they will start losing 8 year Fitbit loyalists.
I have an Apple Watch and a Fitbit versa 3. Yeah crazy, right. I spent a lot of time counting steps and checking both of these watches. The Fitbit was 3 to 8 hundred steps better at being correct on the steps. I count steps on Versa and everything else on my Apple Watch. Just sayin. Have a great rest of your day.
Best AnswerI have a Sense and if the clock face I use has steps, that step count is accurate while the step count on the app and core stats are incorrect. The incorrect counts ultimately match the clock face steps so it would be interesting to know where the authors of the clock face are pulling their count from versus where Fitbit is pulling the app and core stats from.
Best AnswerSame here - for weeks now. This is getting rediculous!!!! I see the problem reported more and more, but I see NOTHING about this being worked on or when a possible fix might be available. A step or two o 10 off is one thing - but this thing can be off by THOUSANDS of steps and then suddenly refresh to I guess what the actual count is.
If I cannot trust the steps I'm getting with fit bit - I'm going to start looking around for other products that do keep accurate count!!!!!
Best AnswerYep! Same issue here! I thought I have been going mad this week but I checked my watch, took a photo of it at 20,000 & then it was down to 19,000.
When I got in from work, I was £14,000, the next minute I checked, I was down to 11,000 steps!
What is going on??
I've uninstalled the app & restarted my fitbit sense but it's still doing it! 😒
Best AnswerI have gotten so annoyed now and now I’m having to charge the watch every two days , I do not know what my actual steps are anymore. I’ve reached 6500 steps five times today and should be on 14000 but my when I’ve sync it five times it’s say 9789
Best AnswerI'm looking into either a versa 4 or pixel 2 and I think the sense 2 is also free of this bug. I love the Fitbit app so don't want to leave the family
Best AnswerI totally get the frustration when your going by the app to get a good understanding of what you need for food and exercise...it's very frustrating, and I'm doing 2 challenges with a third starting next week so I'd like to get a better handle on it
