Unreliable step counting bug
ANSWERED
There is an issue with the step counting as shown here, with the dated Core Stats.
At 15:38 the watch was indicating an erroneous 13,256 steps
After a sync it was showing a more accurate 8,536 steps
How or why this bug has appeared is unknown. It is due to improper syncing/server processing.
There is nothing a user can do to fix this bug, any attempts could make matters worse and be a waste of time.
If the watch is not connected to the Fitbit App, by closing the app [often not possible] or better by turning off Bluetooth, and the steps are correct it would confirm that as the cause.
For Versa/Sense users [not Versa 4 or Sense 2], the SimpleCheckUp app [first screen] might help to know on the watch when the watch last synced.
When turning on Bluetooth again, it is necessary to manual sync a few times to get the correct steps to show.
This bug is NOT related to any watch firmware update or Fitbit App update and applies to all phone and watch types. There will be no update issued to fix it.
Steps counting bug - Update March 20th
It seems this is still not entirely stable and Google may still be introducing changes.
Small adjustments can appear when auto syncing [every 15 minutes about depending on connectivity] or even manual syncing randomly.
Steps counting bug - Update March 19th
After some more testing and in the absence of any official information from Google - the app finally appears to sync correctly without any unwanted adjustments.
Of note, no action by the user was/is necessary for the syncing to be correct, as the error was only at the Google end.
Steps counting bug - Update March 17th
Some people still noticed minor adjustments to the watch steps when syncing, meaning the problem is still not fully fixed.
Steps counting bug - Update April 7th:
The ensuing minor steps adjusting bug that was still prevalent seems also fixed now.
Steps counting bug - Update March 13th:
This may finally be fixed - check steps on your device and manually sync, If the app then shows the same for you it is fixed. However some minor adjustments still seem to occur.
Stress Management Score - Update March 7th:
The missing Stress Management Score that affected all user types [regular or premium] is supposedly fixed now without any user intervention. Though the missing history is not recovered.
For those still not getting it yet please make a separate post/investigation.
316 REPLIES 316
Apparently, version 4.38 was installed on my phone last night. I went running today, and my step count was correct before, during, and after. I hope it stays that way.
Yesterday and so far today, my step counts have been consistent and not doing the wacky jumping around stuff.  Fingers crossed.
Same here.
Hi all,Steps counting bug - Update April 7th:
Some people notice minor adjustments to the watch steps when syncing, meaning the problem is still not fully fixed.
Update March 13th: Initial partial fix
Not seen any official response from Google yet confirming a resolution has been applied for everyone, but there is hope the bug may finally be fixed!
To check, observe steps on your device and manually sync, If the app then updates to show the same number of steps, then for you it is fixed.
A better test can be done by leaving Bluetooth off for a while and then do the above, and note the app changes, from the last synced steps to the new steps that is showing on your device and remains , even if you sync again.
So far it seems ok but will keep watching
Hi @SenseEdmonton
I hope everything is going well. Please let us know the news.
No issue today.  On v4.38.
(why does this forum not allow dates in posts? ie yyyy-mm-dd and even March dd yyyy date format?)
Count seems to be ok as of today March 13th.
Unfortunately, mine is still not acting properly. Does not seem to have quite the wild swings it had before. But while my app will say 1550 steps my watch will say 1600. If I swipe down numerous times eventually my watch will match my phone. Should really be matching my watch as that should be the correct steps. So not fixed for me. And yes I have done all the updates that are available in the Play store. I am on a pixel.
I found that it isn’t exactly fixed too. Now Apple is having an update today so that could screw up something too. It always adds a little steps and calories and miles and floors after I jot down the watch information. Nothing is huge as before, but it’s still not totally fixed in my opinion
Same here.
Not fixed for me (Inspire -steps reducing overnight feed))  took 201 steps off which is far less than usual.  weird though as display of steps with day/week/month/ year & time of day selection was different to ‘steps displayed on ‘today’ for most of the day I just kept syncing, managed to get this correct before midnight and sleep but this morning had reduced again.
I thought the problem was fixed but I found the counts between watch & phone app sometimes are instantly accurate, then at other times several thousand steps off and requires several syncs until counts match again.
I even changed to a new Fitbit Sense but it’s the same issue.
I’m just venting but it seems Google is not very eager to solve this issue & wants us to purchase it’s more expensive Pixel watch! 😤
This has to be the first Inspire person posting I’ve seen!!! I’ve only seen Versa 3 and sense.  Kind of funny though,
In August 2020, Fitbit also announced new smartwatches, the Versa 3, the Inspire 2, and the Fitbit Sense, which includes new health metrics and analysis such as stress sensing, oxygen saturation, and skin temperature. The Sense also promises to show changes in skin temperature to catch signs of sickness. [55]
The google pixel would I think have the same issue. My steps seems to end each day as much higher than I expect
I went for a walk with Bluetooth off on my phone and turned it back on and did a sync and while it looked close I was sad to see the App showed a small amount of more steps than my Sense. Synced another time and it updated the sense to show the same steps as the app. I think it's still adding steps but not reducing to a corrected value. I am showing a lot more over all steps then I think I should have over the last couple days so thinking its not fully resolved.
This is at least my experience. I will do some more tests over the coming days
I found this afternoon whenever I synced the watch to app, the amounts kept changing.  Taking away steps and then adding back up with a different amount.  Definitely not fixed, I was thinking an out the Apple Watch even when I thought fixed.  I need a backup because I don't want to deal with this all over again.  Can't wait to see normal hourly mile which Fitbit never fixed.
Leave the app off until you finish steps for the day. Just ignore it. When
you have finished steps open Fitbit app and quickly let it record your
total. Then quickly turn off the app by removing the app from your screen.
I have also kept the watch turned off or removed from Bluetooth and not
pairing it when asked(hit dismiss). Hope this helps.
Mine isn't totally fixed either, I noticed this over the weekend. Happy St Patty's day
Remove watch from Bluetooth so it can’t talk to phone. Don’t open app. Not sure my last post was clear on that.
