02-24-2022 18:57
02-24-2022 18:57
My Sense watch came yesterday. The only instructions that came with it is a small quick-start guide page. Surely something this expensive should have step-by-step instructions. I came to this site expecting perhaps a video. My watch paired with my phone and shows the time that's it for me so far. I've been able to view my local weather - that's nice - but how do I change temperature info to Fahrenheit? I bought the watch because I read that it could be made to display info from my diabetic CGM Dexcom . glucose monitoring system. Could someone here please help me understand my watch. Thanks for any help.
02-24-2022 20:06
02-24-2022 20:06
Sense help home page including "How do I get started with Fitbit Sense?" and link to Sense Manual (pdf) .
02-24-2022 20:24 - edited 02-24-2022 20:26
Post deleted did not see Johnny’s manual posted.
was in process of posting manual as well.
Best Answer02-24-2022 21:13
02-24-2022 21:13
Thanks so much, Johnny! This is more than I expected. I've got a double-side printer that'll make a nice manual. I'll get right on it. It looks like this will answer any question I may eventually have. Thanks.
02-24-2022 21:14
02-24-2022 21:14
Thank you also, Clove.
Best Answer02-24-2022 22:19
02-24-2022 22:19
HI @montel2 - for your weather see How to change Temperature - for Weather, Centigrade - Fahrenheit, Sense
For Dexcom, this may help Using Dexcom G6
02-25-2022 04:15
02-26-2022 06:49
02-26-2022 06:49
Thanks, I've made a note of it and well check it out later. Right now I'm a bit overwhelmed by all this information.
Best Answer02-26-2022 07:13
02-26-2022 07:13
I started a reply to your suggestion on Thursday after visiting the YouTube video. The video said the info was for only the Versa, but I watched it anyway. I didn't come away with anything helpful, but tried further in my Facebook account where there's access to a club about Dexcom G6. There was info for getting an app for G6 and I went to the app store. But it didn't say anything about the Fitbit Sense... and I overlooked coming back here to finish my reply to you until today. Sorry about that. I got a reminder here when I started a new reply : "You have autosaved content from 08:17" But I didn't find a way to get into "autosave" to try to use in this reply.
Best Answer02-26-2022 10:40
02-26-2022 10:40
@montel2 If you're on your phone, sometimes this site is a little "refresh happy" and you might lose your reply but it will autosave most of the time. You'll see something like this when you tap reply on the same comment and you need to tap "Load".
02-26-2022 13:41
02-26-2022 13:41
I tried to find something that would take me to the auto-save but didn't find anything. Where is the LOAD button located?
02-26-2022 19:15
02-26-2022 19:15
@montel2 Do you not see my screenshot? It says "Load or Discard". You'll only see the autosaved text if you reply I'm the same message you were trying to reply on originally.
Best Answer02-26-2022 20:31
02-26-2022 20:31
@montel2 tap on your user name. This takes you to your profile page where you will see a loathing all your saved, but not published posts. Then followed by all your published posts.
02-26-2022 21:20
02-26-2022 21:20
MY notice of autosave looked just like your screen shot except there was no choice (load or discard) under heath. I was trying to click on the whole blue thing but nothing was happening.. Thinking back about it I think there was an "or" in white letters but definitely not visible the black "load" and "discard". Thanks anyway, you were trying to help. Maybe someone could look into the visual issue I was having.
Thanks
02-26-2022 21:28
02-26-2022 21:28
Yes, that work. Thanks I'm making a note of that. I tried it and found a couple of things to delete.
Best Answer02-27-2022 00:22
02-27-2022 00:22
@montel2 - as @eezeepee has suggested the Load or Delete will only appear if you click reply to the same message that you were responding to previously.
And as @Rich_Laue says, when you are logged into the community and click your profile photo in the top right corner you will see when you scroll down your drafts and related postings, which you can filter, to yours only or yours and responses.
Best Answer02-27-2022 06:27
02-27-2022 06:27
Well, it was the same message I was trying to respond to. But my memory is probably in error if it can't be as I explained. It's all a big learning process here. Thanks for your help.
