03-23-2022
08:58
02:59
03-23-2022
08:58
02:59
Hi @Ref64 - as @deiG says it's known that vibration is weak and it gets weaker as the battery level falls.
There are 8 types of vibration, if you want to try them use the SimpleVibrate app, you might detect Alert or Ring.
Vibration is not a match for the older Ionic and Versa watches.
