07-21-2021
13:28
04:59
LanuzaFitbit
07-21-2021
13:28
04:59
LanuzaFitbit
When I hold the Google help button and ask to take a note (useful for things when I get back to my desk), is there a way to view these notes on a linked phone? Or even a linked Google Account?
Also, I don't know how to delete notes and they are just piling up
Best Answer07-27-2021 10:46 - edited 07-27-2021 10:53
Sounds like your asking Google to take a note. Yes they get stored into the Google Account that you are logged into.
You could ask Google to read your notes, or download a Google note app for the phone.
I use google's Keep Noted.
I would not worry about the notes piling up, Google has a ton of memory.
07-27-2021 11:18
07-27-2021 11:18
Best Answer07-27-2021 12:48
07-27-2021 12:48
Keep notes syncs with your Google account. You need to have your phone logged into your Google account.
You also want the Google assistant in the Sense logged into the same Google account.
07-27-2021 12:49
07-27-2021 12:49
You can also use the Google assistant to add a reminder to your calendar.
07-27-2021 22:37
07-27-2021 22:37
Thanks for this. Yes, this is exactly what I want. Keep notes is synced to my Google account as I am using a Pixel 4 currently.
How do I sync Google assistant on my sense to my account? I can't see the settings option for this??
07-28-2021 02:51
07-28-2021 02:51
You don't sync Google assistant to your Google Account.
When you setup Google assistant you will be asked to log into your Google account. If you did not have a Google account, you will need to create a Google account.
This way whatever you do through Google Assistant will handle your data with the same Google account that your phone uses.
Therefore, using Google assistant in the phone, tracker, or your Google speaker, will all go with the same Google account.
07-28-2021 05:54
07-28-2021 05:54
Sorry to be a pain, and thanks for all of your help but...
My Google Assistant, which is linked to my Google account says that my sense is linked to my Google account. However, the notes still only appear on my actual sense and not on Keep Notes. Keep Notes is also linked to my Google Account. It appears as though Google Assistant on my sense is not then linking to Google assistant on my phone.
Any clues?
Best Answer07-28-2021 07:06
07-28-2021 07:06
Ignore me, I've sorted it. Thanks for the help!
Best Answer07-28-2021 19:07
07-28-2021 19:07
I would double check the account the Sense is linked to.
05-26-2022 13:45
05-26-2022 13:45
How did you manage to sort it, as I'm having the same issue?
08-29-2022 23:30
08-29-2022 23:30
So what is the solution. I have looked at this problem for a while and there are no Notes other than on my Sense. I can't delete them. I can't see them on my Google account?
Best Answer08-29-2022 23:59
08-29-2022 23:59
SOLUTION
So much for this forum for me. After one year of this question hanging. I guessed the solution.
I have an Android phone which comes with a Google Assist (of course) but this is not the same as the Google Assistant App.
Solution Steps:
08-30-2022 02:10
08-30-2022 02:10
Solution Part 2
Regarding using Apps such as Google "Keep Notes" to see the notes you create using the Google Assistant (On phone or smart watch). This is possible if you go into the Google Assistant settings on the phone and there you can choose to sync the notes with a range of Apps including "Keep Notes".
