10-02-2020 21:50
10-02-2020 21:50
Hi,
Could anyone tell me how to get around this problem?
Firmware Version is 44.128.1.42
My language is Japanese
Thank you!
Best Answer10-03-2020 04:44
10-03-2020 04:44
Hello,
So I tested it out and this is what I did. I experienced what you are describing and couldn’t find a way out. What finally worked is this: while on the water record screen, reach all the way across the screen to where the screen begins, swipe from left to right in one long swipe. The screen will move back to the previous menu. Do not try to swipe from the center of the screen. Your swipe must start at the very edge. Hope this helps!
10-03-2020 04:44
10-03-2020 04:44
Hello,
10-03-2020 05:57
10-03-2020 05:57
Thank you for testing. Your advice meets what I want to do.
Below is a request to the developers.
I want you to improve the function so that when you register 0 ml of water, the registration screen will be closed without recording. I couldn't understand the operation without this community.
