Water eject
ANSWERED
Hi I am wondering if the Fitbit sense has water eject feature, I am asking this because the Apple Watch has a feature where if water gets in the Watch, you can eject the water by turning the Digital Crown.
i am wondering if the Fitbit sense has this useful feature because it will solve a lot of issues regarding water damage.
i hope this feature gets added, or if it is already a feature of the Watch, please tell us how to activate it.
cheers.
1 BEST ANSWER
Accepted Solutions
@t.parker   Actually, the Charge 5, Luxe, Inspire 2, and Ace 3, do have a manual water lock.  You are correct about the Water Eject on the Apple watch.  I remember reading a post or two where a Fitbit user wrote that the voice assistant sounded garbled for a while after swimming.
The Sense and Versa 3 set a water lock when you use the Swim shortcut in the Exercise app.  You manually unlock it by pressing the button twice, then you can end the exercise.
Laurie | Maryland
4 REPLIES 4
No Fitbit device supports such a feature. Moreover, no Fitbit device supports water lock on demand. Mind that Apple's Water Eject feature removes only moisture from the speaker (simply, by playing sounds it uses air to push the remaining moisture out of it) and it's part of the unlocking process from the Water Lock feature.
Laurie | Maryland
@LZeeW I didn't know there was the water lock in other models 😯 I can never understand why Fitbit implements features so selectively.
I remember reading a post or two where a Fitbit user wrote that the voice assistant sounded garbled for a while after swimming.”
Thanks for the reply, do you know what the user did to fix the voice assistant’s garbled sound, or does it stay like that forever?
