02-04-2021 19:48
02-04-2021 19:48
Every time water is logged to my app, it does not update on my sense. It continues to say I have my full days worth of water left to drink. Consistently says 0 fl.oz.
02-05-2021 01:12
02-05-2021 01:12
Sometimes when you do things on the watch it doesn't appear in the App immediately.
Is your watch syncing with the App correctly, do new steps appear in the App?
Once its synced did it then show up correctly?
02-05-2021 17:23
02-05-2021 17:23
It’s not a delayed sync issue, as I’ve forced sync to try to get it to update and it will not. Doesn’t work regardless of whether water is logged on sense or in app - remains inaccurate. App is up to date (checked for good measure). Uninstalled and reinstalled - tried everything.
02-05-2021 19:12
02-05-2021 19:12
02-05-2021 21:41
02-05-2021 21:41
Water logging on the watch is a relatively new feature.
There probably is a bug where the daily reset is performed at midnight based on a different time zone. Only if you are in that time zone will it work, correctly, guess that's California.
Any non transference is also a bug, most likely.
