08-09-2021 09:22
08-09-2021 09:22
Weather application won't open. Says I need to grant permission. A triangle and exclamation point appear. In permission button space. Get same message in Maps app also. Tried every permission button I could find. Help!
Best Answer08-09-2021 11:16 - edited 08-09-2021 11:29
If I’m understanding your problem, you can’t see the weather on your sense??
Today page click pic>sense connected>apps>
weather>permissions.
Make sure all permissions are marked.
Restart watch. Log out and back in app.
I use this watch face to continuously display weather. Swipe up and tap weather and double tap for details. Swipe up again for more detail.
08-09-2021 13:02
08-09-2021 13:02
I don't see what you are talking about, this makes no sense. I have gone through the app settings on my Sense, mobile app and on my computer dashboard and don't see anything about weather app settings.
Today page? click pic>sense connected>apps>weather>permissions ???
08-09-2021 13:18
08-09-2021 13:18
Did you purchase the weather app? Then, you will be able to see it. If so, look at the apps and if weather appears, configure your settings. OR, you may have to download again..
08-09-2021 13:29
08-09-2021 13:29
I finally found it...
Best Answer08-09-2021 13:44 - edited 08-09-2021 13:45
You good to go then? How’s the weather? 😂
08-09-2021 20:09
08-09-2021 20:09
I was able after 3 days to find a permission option which I overlooked before. It's where you grant location permission to any apps you need to use for location.
