Hi @LoRainYacht - your sense doesn't measure weight so you have to enter it manually or if you have a compatible scales that records weightlink the app with it.
Best Answer@LoRainYacht Are you referring to your weight that you can see in your Today stats on your Sense? That the weight on your mobile app isn't updating to your Sense? Have you tried any common troubleshooting steps to get it to update? An example would be to turn the weight off on the Sense Today stats, force quit your app, turn the feature back on and see if it updates. How long has this been happening?
Laurie | Maryland
Best AnswerYes. When I enter my weight on the app for the day. It reflects correctly, but it displays my lowest weight not the current weight on the app.'s weight page--at a glance.
Best Answer@LoRainYacht I'm still confused. I apologize if I'm misreading what you wrote. You answered yes to my question, but it sounds like you are describing some that is only on your phone app. Can you describe things a different way? If it is only on your phone app, do you use an Android or iPhone? How long has this been going on?
Laurie | Maryland
