12-06-2022
06:21
17:22
LizzyFitbit
12-06-2022
06:21
17:22
LizzyFitbit
Hi,
I downloaded Clocky3Acid clockface. What "weight" means on Clocky3Acid?
"Weight" stuck on 77.1 and not changing.
Thank you.
Hi @Sergio2022 - it probably us showing what you entered in the App for weight. If you don't change it it will stay the same.
However you can contact the developer, link under see all details at the bottom where you installed it in the app..
You are 100% right, thank you for answer.
