08-28-2021 09:32
08-28-2021 09:32
I want to switch between my sense and other fitbits like a clip on or slimmer wrist option. I had issues with steps not being tracked when switching on the app with my versa and others. Just ordered my new sense but wondering am I going to have the same issues or is it compatible with others in the fitbit app so I won't loose steps?
Best Answer08-28-2021 10:25
08-28-2021 10:25
1) When you say " I had issues with steps not being tracked when switching on the app with my versa and others.", if you mean actually going into the phone app and adding a different tracker to remove the current one, then doing opposite switch every time, that should work as long as you complete a sync before every switch, though it would get troublesome to keep switching.
2) For 2 models on same account that can switch without doing the above-mentioned swap, your choices are limited to older models, none of which I believe are still sold new.
From Can I use more than one Fitbit device with the same account?
So it would have to be a model not listed on box above.
