When I try to connect WiFi through the app my iPhone finds only the 5 ghz network so I can’t connect my sense to my home network. In order to set up my sense I had to use a hotspot from a different iPhone than the one I’m running the Fitbit app on. It worked but I’m trying to connect directly to my home network without having to use a hotspot. With my Ionic I didn’t have a problem connecting to my WiFi network at home. I don’t understand why this is so difficult.
Hi @Jshake1 Have you tried to temporarily disconnect your iPhone from the 5Ghz network? It should force your iPhone to connect to the 2,4 Ghz, and connect your Sense to WiFi.
Best Answer@Jshake1 , that can be a bit tricky. Sense uses the 2.4 GHz band and will not be available for setup if your phone is on the 5 GHz band. You only need 2,4 on your phone for setup. Unless you can set up a 2,4 guest network on your router, the only option I can think of is to move out of the 5 GHz range (2.4 broadcasts longer than 5Ghz).to connect Sense yo wifi.
Best Answer@Jshake1 it can be interference bluetooth / wifi. You can try to unpair Sense / Phone, and then try to add WiFi again. You won't loose any data by unpairing.
