I have tried several times for my FitBit Sence to connect to WiFi on my iPhone. I have an 8plus iPhone and have tried after every update for it to connect to the WiFi with not luck. Any help will be appreciated on how to connect Sense to WiFi.
Best AnswerI have tried several times for my FitBit Sence to connect to WiFi on my iPhone. I have an 8plus iPhone and have tried after every update for it to connect to the WiFi with not luck. Any help will be appreciated on how to connect Sense to WiFi.
Hi, just in case, a Sense only uses WiFi on the 2.4 gHz frequency, it won't connect if the one you are using is at the higher speed only.
