10-03-2020 17:55
10-03-2020 17:55
Since I have to have the Sp02 watch face on while I sleep to do the appropriate tracking, I switch out the watch face every night before bed but then switch back to one I like in the morning. This should be possible without the phone app but 95% of the time it is not. Once in a blue moon, I can get it to work but the rest of the time, no joy.
I navigate to the Clocks app and slide to the one I want and select it. 95% of the time it immediately goes right to the the watch face I am trying to change from. I've tried tapping, pounding, holding double tapping, pressing, etc. Still, it does mot work. Help.
10-09-2020 07:35
10-09-2020 07:35
The switching situation appears to be resolved. It now works as designed 95% of the time. I figure that last 5% is user error.
I still think it's ridiculous to have to switch to a specific watch face every night but at least I can now do the switching.
10-03-2020 17:59
10-03-2020 17:59
Yes, Fitbit, please respond to this issue. I have the same problem, but it seems to be worse when clock is set as a shortcut. It never works when its a shortcut, but works most of the time if navigating to it on the watch.
10-04-2020 08:45
10-04-2020 08:45
Swipe left to the app called clock. Tap and pick the wanted clock. Tap the button to return to your chosen clock.
You van store up to 5 clocks on your tracker.
10-04-2020 08:51
10-04-2020 08:51
I have 5 clocks stored. NONE of them load the way you describe on the first try. Sometimes, after multiple tries, I can get a change. Mostly not.
I have no trouble changing them from the phone app. But that's a PIA when you have to do it twice a day.
10-09-2020 07:35
10-09-2020 07:35
