if fit bit is going to update and require a phone restart to continue notification, could you add an alert/notification for that please? before hand of course. 🙂 i get half way through my morning and find i have missed important texts. i use the wrist notifications so i can concentrate on my task at hand. thank you!
Best AnswerHi, @Gidge13, welcome, you should receive notifications from your phone on your device, you may need to check the vibration is set to maximum so you do not miss it. From the clock screen swipe left to settings>vibration & audio,>set the vibration to strong. Make sure you do not have Do Not Disturb or sleep mode engaged (they stop notifications) This article How do I get notifications from my phone on my Fitbit device? gives advice and guidance.
I hope this helps, let us know how you get on.
Cheers
Gr4ndp4 | UK
