Am I just overlooking it, or is it impossible to set an auto-pause function when using the Sense when walking? When using GPS during a walk, unless I remember to pause/resume I catch myself failing to pause it if I stop to talk to someone or whatever, which totally skews my time and pace. Even the Runkeeper app on my iphone can do this.
Best AnswerTo this point is there a difference between the "Running" vs "Walking" exercise? Meaning what's the harm of using "Running" and just walking other then the fact the activity name in your history will reflect a Run instead of a Walk?
Since they are both nearly identical outside of the name hopefully they provide an update that provides parity between the 2
Best AnswerOn my. Harge 5 I don't have auto pause on both walk run or bike. It is very disappointing and hope the add this feature in
Best Answer@TTLAY The Charge 5 has an auto-pause option for the Run shortcut, but not Walk or Bike. You can find this in the Run settings on the device itself. Charge 5 manual This feature was added to the Sense 2/Versa 4. I doubt that Fitbit will add it to your Charge 5 or my Versa 3. Fitbit just doesn't seem to work that way.
Laurie | Maryland
