04-23-2022 19:05
04-23-2022 19:05
As a result of the Ionic recall, I recently purchased a Fitbit Sense. I have found that there is a significant difference in calorie counts between one and the other when cycling.
(1) During similar bike trips of 30-40 miles, and similar duration, the burn rates are much lower in the Sense that they are in the Ionic:
Ionic: 50-70 calories burnt per traveled mile.
Sense: 10-25 calories burnt per traveled mile.
This is not a single case, but a systematic difference for different trips.
(2) I did a second experiment: During a 45 mile trip, I wore the Fitbit Sense and the Ionic at the same time. The results were:
Ionic: 51.1 calories burnt per traveled mile.
Sense: 10.0 calories burnt per traveled mile.
Note that all personal parameters are the same in the Sense and in the Ionic: weight, height, dominant arm, etc.
I have not noticed differences in calories burnt when I walk, or in the "background" calorie burn. But for cycling, the differences are too large to ignore. I infer that there is either a hardware issue (sensor) or a software one (error in algorithm to compute calories while biking).
I will appreciate opinions, but more than anything, if someone at Fitbit reads this, please offer a solution.
For those interested, here is a table with more details:
Date | Steps | Total Cal | Bike time | Bike distance | Bike cal | cal/mi | |
Ionic | 12/20/2021 | 4650 | 3866 | 3 h 26 m | 33 | 2239 | 67.85 |
Ionic | 12/28/2021 | 4000 | 3371 | 3 h 46 m | 36.1 | 1795 | 49.72 |
Ionic | 3/21/2022 | 6292 | 3913 | 4 h 44 m | 39 | 2247 | 57.62 |
Sense | 4/2/2022 | 6056 | 2223 | 1 h 50 m | 16 | 300 | 18.75 |
Sense | 4/13/2022 | 6780 | 3279 | 4 h 10 m | 42 | 1012 | 24.10 |
Sense | 4/20/2022 | 5300 | 2509 | 4 h 35 m | 45 | 452 | 10.04 |
Ionic | 4/20/2022 | 45 | 2300 | 51.11 |
04-29-2022 05:05
04-29-2022 05:05
I've noticed the same. Calories per min burned biking is lower than walking. I just biked to work. A 370ft elevation gain over 3.77 miles, so uphill most of the way, with additional weight (clothes, toiletries, computer, lunch), and calories per min comes out 1 calorie less than a normal paced walk I took the other day over flat terrain carryingnothingbut my phone and house keys. 87 calories over 24 mins of heart pounding uphill riding. It doesn't make sense at all. No pun intended, I swear.
