08-29-2014 22:08
08-29-2014 22:08
I have Restless Led Syndrome and I just started tracking my sleep patterns with the Flex. It is amazing! Not my sleep pattern, but the fact that this device tracks my "awake" periods and my "sleep" periods to the minute. I can share this with my doctors AND with the other people I know who have this disease. If there are any others out there who would like to start a group, please let me know.
I also track everthing else. I am very active and would love a challenge or 2, or 3......
CW
04-01-2016 14:00 - edited 04-01-2016 14:01
Im not sure what your asking? It is normal to see a lot of light Blue in.sensitive mode.
Do you move around a lot when asleep?
In normal Fitbit ignores the small movevements, in sensitive it shows you them. Personally I would like to see a graph to see how far the movements sre, not just that I moved.
Several people have worn their Fitbit during a sleep study, and found the Normal setting pretty close.
04-01-2016 17:50
04-01-2016 17:50
Asking if that looks normal in this thread may not tell you much because this is why we are here. When I turned mine to sensitive mine looked similar. I decided that the standard mode was far more reflective of reality for me with a Charge HR. I have RLS and chronic sinusitis. The sinusitis makes me flop all night to drain the side of my head that had filled up and restricted my breathing. My restless leg issue shows up more before bedtime and in the first hour of attempted sleep. I will either find my legs so restless (and perceive pain) that I must move then progressively more until I am moving them every 1-3 seconds OR I will awake jerking a leg or in a couple of instances, swinging my arm like a prizefighter. I have been on 0.5 mg of pramipexole for about a year now- and as long as I take it 2-3 hours before bedtime 1 dose works like a charm and I do not have any side effects. Do I worry about long term effects? Maybe a tiny amount- my dad passed away after suffering for years with a Parkinson's like syndrome which this drug is one of the options they treat it with- but perhaps that is irrevelant.
Back to your chart- I think mine would still look like that today if i put mine in sensitive mode due to the sinusitis. In standard mode my chart would show only 12-20 awake periods depending on how bad my sinuses are acting. If i have more than 15-16 awake periods I will not be refreshed after sleep. I am usually very tired when i wake up. At least the medication allows me to get to sleep.
Hope this helps- but it is only my experience.
04-01-2016 17:53
04-01-2016 17:53
BTW- if you have RLS avoid alcohol at all costs- it will negate any medication (or at least what I take).
07-16-2017 11:22
07-16-2017 11:22
I am a new Fitbit Blaze user, primarily to track my aweful sleep. I have RLS which causes The Fitbit not to measure until I am still. I have been taking .5 mg Clonapin to help with sleep, not!,
Sleepless in Asheville
07-20-2017 19:27
07-20-2017 19:27
I too have restless leg syndrome. I take Pramipexole and it really helps. If I wait too long at night to take the Pramipexole I can't get to sleep for hours. I need to take it 2-3 hours before I want to sleep. It does help to eat an apple or fruit with it.
Massage does help. If I get a massage every two weeks I can cut down on the dosage of Pramipexole. Exercise doesn't help or hinder my RLS.
I'll try the tonic water and see if that works.
07-25-2017 20:07
07-25-2017 20:07
I will try to go without grains (easy) and milk products(No cheese is going to be hard!) this month and see if it helps. Thanks for the tip. I'll willing to try anything to get off meds.
07-25-2017 20:40
07-25-2017 20:40
07-27-2017 13:42
07-27-2017 13:42
Sometimes I sit on the floor and pound my legs on the floor. That works better for me than walking
08-16-2017 20:13
08-16-2017 20:13
Does the medication make you nauseous? I quit taking Ropinirole for that reason. I have bad Sciatica which seems to aggravate the RLS and also Periodic Limb Movement Disorder. I take Hydrocodone, Cyclobenzeprene and Gabapentin. Sigh! I'd like to ditch it all.
08-16-2017 21:27
08-16-2017 21:27
03-13-2019 04:09
03-13-2019 04:09
Hi, I too suffer with RLS, when I wake up, my Fitbit says I have done 192 steps already this am. Does it count my leg movements in my sleep? Thanks
03-13-2019 04:36
03-13-2019 04:36
03-13-2019 12:00
03-13-2019 12:00
True @JKH2 The Fitbit is connected to the arm not the foot.
03-13-2019 21:29
03-13-2019 21:29
03-13-2019 21:37
03-13-2019 21:37
Sometimes I turn over just so I can not bother my hubby.
