The sleep tracker is showing the amount of time I'm awake, restless sleep and how long it takes for me to fall asleep, but not REM, etc... Is my wrist just too small? I'm VERY TINY - under 100 lb, even on a "fat" day. The wristband is on the smallest hole.
Thanks!
Hi @writergal28 I'm sorry to hear you are having an issue tracking your sleep. Will you please share few more details. For example, do you see % of Awake, Light, & Deep? If you see those three, if the REM at 0% or not displayed at all? If you aren't seeing any of those, how long are you sleeping? If you aren't sleeping more than 3 hours, that data won't be available. With a bit more information, I'm hope we can solve this issue for you. Best of luck!
I've figured out why it isn't tracking - it's because I was manually turning on my sleep tracker! It's fine now. Thanks.
