05-31-2014 04:26
05-31-2014 04:26
I set my fitbit for sleep when I go to bed and when I awake for the day I tap it to take it out of sleep mode.
When it syncs with my computer or ipad, it just shows what time I started it and stopped it eg, 22:57 - 6:57 = 8h
I know that I was up at least twice diring the night but it is just a solid blue line. Can you help me?
Best Answer05-31-2014 05:45
05-31-2014 05:45
I would recommend sleeping more soundly, then your sleep pattern would match what your fitbit says 😜
I'm sorry I don't have a serious answer, but there is more than one way to sink a ship.
Best Answer05-31-2014 06:22
05-31-2014 06:22
I don't have a fitbit myself yet, but I'm pretty sure I read a similar problem somewhere that was fixed by performing a reset... let me see if I can find it for you
Best Answer05-31-2014 06:32 - edited 05-31-2014 06:34
Right, this is what I found https://help.fitbit.com/customer/portal/articles/1041329-how-do-i-restart-my-tracker-
This is supposed to be a fix for problems including no tracking of movement. Of course this is based on the assumption that it has worked properly before. If not, you might want to read this https://help.fitbit.com/customer/portal/articles/1230068-about-sleep-tracking and check sensitivity settings
Best Answer06-02-2014 07:18
06-02-2014 07:18
I'm ambidextrous; ordinarily I use one hand for some things; the other for others. Therefore, I can't "wear on non-dominant hand".
1. Will Fitbit record hand movement on both sides?
2. What is the threshold for movement? If I walk carrying something in the hand with the Fitbit and do not therefore move that arm while walking (my dog's leash, for example), does that mean the steps are not recorded?
3. My work is largely done on a computer 5 days/week. Those hours should have a BMR-level of "step equivalents" recorded -- I get that -- but not actual steps. Does even hand movement (typing, moving a mouse, etc.) rack up steps? I hope not!
Best Answer06-04-2014 13:52
06-04-2014 13:52
change your sleep sensitivity. it might be on normal just now
