08-01-2022 09:19
08-01-2022 09:19
Hi, after years of use the fitbit Alpha HR I got a new Luxe with the new software upgrade but the readings fo HRV seems extremely low - 15-17ms - which would suggest I am very ill! I am quite a stressed person but also fairly fit - RHR 55-65 which is apparently excellent for a woman my age. Has anyone else had issues with low HRV readings?
08-01-2022 09:30
08-01-2022 09:30
Did you get HRV values from your Alpha HR (don't think there is any such Fitbit model)? If not, I would be inclined not to compare Fitbit's HRV values to what you may have seen from other sources, but rather look at the trend of the Fitbit readings.
Best Answer08-01-2022 10:12
08-01-2022 10:12
Best Answer08-01-2022 11:18
08-01-2022 11:18
Do not make much of it. First it is some form of average and you have no access to the underlying data.
What you need to look at is the trend, does it decrease, does it increase ? Not much more. And I am not sure you can see more than 7 days of data. On 30 days mine are quite erratic.
Best Answer09-18-2022 00:45
09-18-2022 00:45
Hi there. I'm getting very low numbers too.. 22 milliseconds average. It is quite concerning. My heartrate is low too.. 49 - 54.. but I'm generally healthy.. Did you ever get any satisfactory answers to this query?
Best Answer09-21-2022 06:03
09-21-2022 06:03
49 to 54 is a great resting heart rate. My RHR is around 55 to 58 and my HRV has been stuck at 16 to 26 since I got my Fitbit 2 years ago. There have been multiple complaints about this over the years. I’ve made peace with simply watching my HRV relative to my own range.
I think Apple’s HRV measurement is much more accurate than Fitbit.
Best Answer09-21-2022 07:08
09-21-2022 07:08
