When I use to go to my dashboard, my sleep was automaticlly logged. When I went to where I could log sleep, there was the place that I manually could enter it and below was where it showed the data after it was snyced that I could edit. This morning all I have is where I can enter the data manually, there is not section showing from my band what I slept. What happened, what did I do and how do I get it back to automatically get the data from my band?
Best AnswerSilly question, but did you end your sleep session on your band by tapping it quickly to deactivate sleep mode?
Started with a Flex. Now have ChargeHR.
Contact Customer Support
Best AnswerI have the charge HR so I do not have to put it in sleep mode. It is not the bad, I clicked on something in the dashboard and that entire section disappared. I found my old sleep data in my activities log but no way to get it back to sleep log
Best AnswerI only know how to do this from a computer. Go to your dashboard, look on the left side there is a circle with 9 small squares in a circle. Click this and it will show you tile options to add to your dashboard. Maybe your tile got accidentally moved over to there?
