01-26-2015 10:57
01-26-2015 10:57
I have set the alarm twice and it isnt vibrating or lighting up. I also thought it would vibrate today when I had done 20% of my steps. I only got it yesterday, should it be vibrating more?
Best Answer01-26-2015 13:57
01-26-2015 13:57
Hi
If you are using a fitbit flex it only vibrates when you have done 10,000 steps.
I use my wake up alarm daily, so maybe you just haven't configured it right?
Give it another try
And enjoy the fitbit experience☺
Best Answer01-27-2015 15:25 - edited 01-27-2015 15:29
It only vibrates when you've reached your step goal. The lights do represent the percent of goal reached - so one light is 20%, two lights 40%, etc.
Best Answer01-28-2015 09:50
01-28-2015 09:50
Thank you both for that advice. I hadnt synced it for the alarm and just hadnt read instructions properly about the lights and vibrating. I think I have that bit now. But........
Can you also tell me why bother putting it in sleep mode when you go to bed?
Thanks.
