04-13-2014 13:08
04-13-2014 13:08
Hi All,
I am new to Fitbit this is only my second day using. I did track my sleep yesterday and it gave me a 100% on sleep efficiency. I am a deep sleeper and sleep well but last night I do remember rolling over and waking a few times. How accurate has the sleep tracker been for all of you? And what is the typical percentage that you get?
Thanks!
Amini
Best Answer04-14-2014 09:27
04-14-2014 09:27
It it works, please come back and mark the question as resolved.
Best Answer04-13-2014 15:17
04-13-2014 15:17
I wake up a lot at night, because I have asthma, I cough a lot when I am asleep. It typically tracks everything. Go to your account and check the sensitivity. There are two settings, sensitive and normal. You may need to set it to sensitive.
Best Answer04-13-2014 15:18
04-13-2014 15:18
My efficiency rating is typically 92 - 95.
Best Answer04-13-2014 18:24
04-13-2014 18:24
Thank you! I will change the setting and see how that works.
04-14-2014 09:27
04-14-2014 09:27
