06-20-2016 16:32
06-20-2016 16:32
Good afternoon Community!
You may have heard or read about our new sleep feature called "Sleep Schedule." Consistency is key when it comes to many good habits, and so getting on a consist sleep schedule is something that we hope will improve your sleep! Along with your sleep goal, you can now also set a bedtime goal and wake up goal, as well as get a reminder to start winding down a little bit before your bedtime goal time!
Here's a post from our blog about why getting consistent sleep is important. If you have questions about this feature, here's the relevant help article.
Let the Community know how this feature has helped you get more sleep, or other things you've experienced when using this feature. We'd love to hear from you! Happy sleeping 🙂
06-20-2016 16:58
06-20-2016 16:58
I can't find where to set the new sleep schedule feature, please help. There is no additional tile appearing on my dashboard, nor is one available to load. I have the Charge HR, and received the New Feature email.
Thanks,
Louise
Best Answer06-20-2016 19:02
06-20-2016 19:02
06-20-2016 22:38
06-20-2016 22:38
Same problem with the Alta. I've logged out and back into the app, turned my phone off and on...and simply cannot find the way to set up sleep tracking.
Best Answer06-20-2016 22:48
06-20-2016 22:48
AH HA! Go to Google Play and update your app. Now it works!
Best Answer06-21-2016 03:11
06-21-2016 03:11
Best Answer06-21-2016 07:56
06-21-2016 07:56
Best Answer06-21-2016 11:17
06-21-2016 11:17
@_Louise_ thanks for reaching out! This new feature is not encompassed by a new tile - instead, it is within the sleep tile that you can set a Sleep Schedule. If you go to your dashboard on your mobile device and click on the gear icon, you should see the Sleep Goals page pop up. Here, you can set the Sleep Schedule. Let me know if you have any other questions!
@PDX_Karen I'm glad you figured out where to set the Sleep Schedule! Thanks for troubleshooting 🙂
@Scott4 if you click on your sleep tile within your app, please click on the gear icon. If you don't see the Sleep Goals page pop up, please let me know! Screenshots are always helpful as well. Thanks!
Best Answer06-22-2016 05:57
06-22-2016 05:57
I set my sleep schedule yesterdat and I noticed today that my tracker did not even log my sleep time automatically. I have the flex. Am I doing something wrong? Thanks
Best Answer06-22-2016 06:33
06-22-2016 06:33
06-22-2016 13:14
06-22-2016 13:14
Best Answer06-23-2016 05:22
06-23-2016 05:22
I have not got this new update on my app. I have deleted the app and re-downloaded it multiple times and there is no new feature or update available in the app store. I have a charge HR and a Samsung device. Would love some assistance.
Best Answer06-23-2016 06:54
06-23-2016 06:54
Hi @CallieM. Yesterday I had to manually put in my sleep for some reason. I changed some setting and it appears that it logged my sleep last night. So not sure what I did wrong. I just wanted to make sure that I did not have to go back to setting my device to sleep or remembering approximately when I get in the bed. Thank you!
Best Answer06-23-2016 13:58
06-23-2016 13:58
@Ing thanks for the update - glad it's working now!
@Roselefit thanks for reaching out! Please follow these instructions to find your Sleep Schedule feature:
Please let me know if you can or can't find it using these directions - thanks!
Best Answer06-23-2016 17:04
06-23-2016 17:04
Best Answer06-26-2016 20:54 - edited 06-26-2016 20:59
I found this on my Andriod phone but cannot find on Windows 10 even though I tried to follow the instructions. Has anyone actually found it on Windows, I assume from the dashboard, the only things I can set from the sleep tile are sleep length goal, and manually log sleep. Does it maybe work only on touch screen mode but not in traditional keyboard mode such as on a desktop? I think everything else has been accessible from traditional desktop.
Best Answer06-28-2016 16:38
06-28-2016 16:38
Click here for more information about how to set a sleep schedule.
@Roselefit I'd recommend making sure that you are using the most current version of the Android App. Click here to be redirected to the Google Play Store. After you've updated, you should be able to find the sleep schedule using the instructions that @CallieM mentioned in her post.
@JohnnyRow I'd also recommend making sure that your Windows 10 app is the most up-to-date version. Click here to be redirected to the Windows App Store. Afterwards, you should be able to access your sleep schedule by:
1. Clicking the tile that says "How did you sleep?"
2. Tap the moon icon at the bottom.
3. Set or edit your targets. To remove a target, tap the three dots in the bottom.
4. Click save.
Best Answer07-22-2016 08:34
07-22-2016 08:34
my computer recently had a tune up and now I've lost all my data , My steps are not registering and no sleep mode also I had to put in a different email address as the site would not accept my old one ..what do I do .Should I try to reset the whole thing and if so please give me some direction . Its a Fitbit Alta
Ricoma
Best Answer09-28-2016 12:21
09-28-2016 12:21
What am I missing here? There doesn't seem to be anything "extra" within the Sleep tile on the dashboard. I click on it - and it will let me add or change a sleep record, and the tile shows me the usual information - but I don't see anything to suggest that it would remind me that it's time to unwind and go to bed. Not that I need that - but honestly, there are times when that would be helpful.
I don't see this option and I feel like I've clicked through every thing clickable.
