10-29-2017 21:17
10-29-2017 21:17
This is the 5th night my Blaze is not tracking sleep stages. I had an issue with syncing so I chatted with support. I updated it and restarted the Blaze. It is still not tracking sleep stages. I only get the sleep pattern like I did on the Charge HR. Does anyone know what is going on or how to fix it?
Best Answer10-30-2017 04:49
10-30-2017 04:49
Is it tracking your heart rate OK as without this there are no sleep stages? I've had this happen on the odd night when it doesn't pick up HR for whatever reason.
10-30-2017 04:49
10-30-2017 04:49
11-03-2017 19:54
11-03-2017 19:54
Brittanykelpin
Best Answer11-06-2017 05:05
11-06-2017 05:05
Just to make sure, you are not starting the sleep tracking in the app? When you do that it won't register sleep stages. For that you should let it automatically track your sleep.
Karolien | The Netherlands
11-06-2017 08:29
11-06-2017 08:29
Thank you! Somehow the "heart rate" button got turned off. Maybe when I had to restart it. Still having syncing issues though. 😕
11-06-2017 09:57
11-06-2017 09:57
Good to hear you made progress. When I have syncing issues I disable bluetooth on my phone for 10 seconds. That typically solves it for me.
Best Answer11-06-2017 13:52
11-06-2017 13:52
THANK YOU! I will try that!
