06-27-2019 06:25
06-27-2019 06:25
I’ve been getting odd sleep readings lately, and wondering if anyone has had it happen to them. For instance, last night it shows that I slept from 9:07-10:37, and 9:43-1:05. This is not the first time it’s happened, and I have tried resetting.
08:46
13:19
LanuzaFitbit
06-30-2019
08:46
13:19
LanuzaFitbit
Welcome to the forum. Let's start with a few questions, so I can better help you. What type of tracker do you have? What is the main goal you are trying to track (steps, distance, sleep...). Depending on your goals and when you plan to wear your tracker, you may want to set up your reminders to move during a limited time (perhaps in the evening after work).
Moderator edit: Removed personal info
