The device uses motion and heartrate to infer sleep. If you are still and your HR goes down, it might gauge that you are asleep. Some models have sensitivity settings you can modify. Since it’s getting tricked when you’re just resting, your sleep metrics might be more accurate if you lower the sensitivity. Hope that helps.
