05-26-2016 16:55 - edited 05-26-2016 16:55
Hi everyone,
Tomorrow I will be taking a redeye flight about six hours long. Then, a few days later, I am back on the plane, but not taking a redeye. I will likely attempt to sleep a little bit as this flight will be longer and later in the day. Anyone have any advice about how to get the best sleep I can while on the flight? I know airplanes suck in general for sleep but any help would be appreciated!
Best Answer05-26-2016 17:19
05-26-2016 17:19
Hi, i found the best way to sleep is to bring foam ear plugs with. the kind that you pinch in your fingers and put in your ears. this will block out a lot of noise but still let you hear if there is an emergency.
I also take my shoes off so my feet can help regulate my body temp as i sleep. it sounds strange but i can't sleep with shoes on.
Best Answer05-27-2016 16:36
05-27-2016 16:36
Thank you for the suggestions! I'm going to try both of these on my flight. Thanks much 🙂
Best Answer06-06-2016 12:05
06-06-2016 12:05
@Pensive I completely agree with @SunsetRunner! Those foam earplugs are the best. My favorite brand is Mack's - find them here!
A couple other things I like to bring when attempting to sleep on a plane:
-Try to get your significant other in a seat next to you so you can sleep on his or her shoulder (haha- just kidding)
-A comfy sweatshirt with a hood that can be pulled down over your eyes to shut out brightness
-Relaxing herbal chamomile tea (when the steward comes around asking for your drink order, just order hot water)
-Don't wear jeans or constricting clothing. I always try to wear my comfiest pair of leggings - lululemon has the best ones that also are acceptable in public ![]()
Hope this helps! This is a great discussion topic, @Pensive thanks for posting it here!
